August 29, 20251 yr My BuzzTV box has become extremely slow in loading up VOD programs and TV channels when I switch from VOD to Live TV. I have to restart the device or choose the Refresh option which takes a few minutes. This happens at least once or twice a day and only on Buzz TV box. The other boxes have no such problem. The internet speed to the box is 150Mb+. Any suggestions to minimize the delay?
August 29, 20251 yr What buzz box model do you have ? And how many other things have you installed on the box ? And what firmware/software version is installed ? If you don't have too much 3rd Party apps installed, you can always backup BuzzTV 5 to a USB stick, then do a factory reset and restore your BuzzTV 5 settings. Edited August 29, 20251 yr by Emporium
August 29, 20251 yr Author My model is X5 64AI. The box shows that I have the latest update which was installed on September 23, 2024. Firmware - V20240918 I haven't installed any new 3rd-party apps besides the the ones that came with the box. Question - Is there one place I can go to clear the cache on my box? I am clearing the cache going into each app. However, the cache size is relatively small in all apps including the Buzz TV app < 100 MB.
August 30, 20251 yr Author I have deleted and then reinstalled the server. For now, it is behaving all right but will observe it for the next few days. Thanks for your suggestions.
