July 1, 20251 yr audio optimizer some station the volume is way too loud and won't turn down unless it is turned off is there a audio optimizer I can download and which one works with Buzz?
July 1, 20251 yr 19 minutes ago, Nunzio D said: audio optimizer some station the volume is way too loud and won't turn down unless it is turned off is there a audio optimizer I can download and which one works with Buzz? You have force max volume off?
July 1, 20251 yr 3 hours ago, Nunzio D said: audio optimizer some station the volume is way too loud and won't turn down unless it is turned off is there a audio optimizer I can download and which one works with Buzz? Like NBS mentioned, turn max volume off, and that will allow you to control the volume using the Buzz remote. If you already have it off, continue reading below. What is your setup ? just basic sound from TV speakers, or a basic soundbar.. OR full blown surround sound, etc.. ? If you are only using stereo you can try the following it should disable the auto detection of some 5.1 streams which can cause controls to be a little unpredictable. If your setup does not support 5.1 audio, try disabling the auto detection.. From Home screen, Settings (Gear icon)->Device preferences->Display and Sound->Advance sound settings->Select formats (and select "none: never use surround sound").
July 1, 20251 yr Author 1 hour ago, Emporium said: Like NBS mentioned, turn max volume off, and that will allow you to control the volume using the Buzz remote. If you already have it off, continue reading below. What is your setup ? just basic sound from TV speakers, or a basic soundbar.. OR full blown surround sound, etc.. ? If you are only using stereo you can try the following it should disable the auto detection of some 5.1 streams which can cause controls to be a little unpredictable. If your setup does not support 5.1 audio, try disabling the auto detection.. From Home screen, Settings (Gear icon)->Device preferences->Display and Sound->Advance sound settings->Select formats (and select "none: never use surround sound").
