January 9, 20224 yr Just now, Raees said: Yes Its likely a hls stream which cant be downloaded Its difficult determining some hls streams Buzz are working on the messaging
January 9, 20224 yr 9 minutes ago, Raees said: Yes and did you select it for download storage in pvr options?
January 9, 20224 yr Author 1 hour ago, dishuser said: and did you select it for download storage in pvr options? Yes
January 9, 20224 yr Author But just to confirm..its wrking very nice today..my wifey not so much but my 10 yr old love the new update. He loves the fact that the episodes looks and feels like youtube..very user friendly.
January 30, 20224 yr Author Everytime i turn the tv off,box will go in sleep mode automatically..thats perfect. But when i turn the tv on..the box will not turn on automatically. I would allways have to turn it on using buzz remote. plz let me know if there is any fix for this.
January 31, 20224 yr 33 minutes ago, Raees said: Everytime i turn the tv off,box will go in sleep mode automatically..thats perfect. But when i turn the tv on..the box will not turn on automatically. I would allways have to turn it on using buzz remote. plz let me know if there is any fix for this. home page/settings/advanced settings what is powerkey definition set to?
January 31, 20224 yr 1 hour ago, Raees said: Everytime i turn the tv off,box will go in sleep mode automatically..thats perfect. But when i turn the tv on..the box will not turn on automatically. I would allways have to turn it on using buzz remote. plz let me know if there is any fix for this. https://stbtalk.com/index.php?/topic/1498-cant-get-into-settings/#comment-8756
January 31, 20224 yr Author 2 hours ago, dishuser said: home page/settings/advanced settings what is powerkey definition set to? Powerkey definition set to suspend.
January 31, 20224 yr Author 2 hours ago, Maestro701 said: https://stbtalk.com/index.php?/topic/1498-cant-get-into-settings/#comment-8756 This didnt work.
January 31, 20224 yr 44 minutes ago, Raees said: Powerkey definition set to suspend. Try setting it to shutdown
January 31, 20224 yr Author 40 minutes ago, nbs. said: Try setting it to shutdown Ok set to shutdown but still wont turn on when turn the tv on. Only shuts off when turn tv off.
January 31, 20224 yr 38 minutes ago, Raees said: Ok set to shutdown but still wont turn on when turn the tv on. Only shuts off when turn tv off. press power button and hold now you get 3 options
January 31, 20224 yr 6 hours ago, Raees said: This didnt work. Your TV should also have the HDMI cec option. If it does you must enable it too. Hope it works for you
February 2, 20224 yr Author On 1/31/2022 at 5:02 AM, Maestro701 said: Your TV should also have the HDMI cec option. If it does you must enable it too. Hope it works for you Its enable in tv. The issue is..it only turns off the box when i turn off tv..it would not turn on automatically when i turn the tv on which i really would like it to.
February 2, 20224 yr 1 hour ago, Raees said: Its enable in tv. The issue is..it only turns off the box when i turn off tv..it would not turn on automatically when i turn the tv on which i really would like it to. OK, it's the turning on of the box you need when tv is turned on. It's not working for me either. I know it used to work way back on the 3000 series but haven't used it since. Will play around with it some more and keep you posted.
