Is it possible on 6 Power Station to making a template clone & Cloud DVR
Is it possible to make a template 6 power station for loading other 6 power station. I would be great for loading 5 of them with the same template.. And is there a way to used cloud base DVR on your network so all of the 6 power station would share from it.
Smiley
Hi Emporium
Yes, the server setting and favorites and channels line up. So each one looks the same under live channels and movies and series. And where do you same that on to a flash drive.
Thank You
Smiley
45 minutes ago, smiley2069 said:
Hi Emporium
Thank You
Smiley
Menu-settings -configuration - app settings-backup and restore
The 6 power station 16 g there is no Menu-settings -configuration - app settings-backup and restore. I went through all menus and server menus.
Is there any other way to do this on this model?
Smiley
Did you hit menu button on remote?
Whats firmware on your p6?
Smiley
In live tv hit menu button then do the thing
Edited by pugsycan
