Stream Error banner in lower right corner
Is there a way to turn off the Stream Error banner in lower right corner?
I don't see any issues with the picture or audio... don't really need that notice,
I disappears in seconds on it's own, just annoying
Thanks sts41
Ive had that issue myself.. no problem with stream just keep getting that message. Its vety annoying lol
There is obviously something the current player doesn't like in the way it interprets the stream 🙂   I think the best is to maybe message Buzz with details on which service, what type of sub (MAC/XC..) and which channels are causing the issue, so they can try to see if it is possibly a "bug" in the player.  The easier it is for them to reproduce, the better chance of getting a fix.
I ve got mac server and it happens prettty much all the time on all channels.it only occurs on live tv channels vod has no issue
Mine is same as Woody, MAC and only live..... Even catch-up doesn't do it. I also have an XC sub that doesn't do this.
I was hoping it was just a switch I could turn off. I will deal with it.
If you would like to know the service, just let me know who to message with that.
Allaboutbuzz would be the one
