October 1, 20242 yr Do you have another device you can check with ? Or check using BuzzTV 5 on the P6, just to ensure it is not your service ?
October 1, 20242 yr 2 hours ago, TonyC said: They are all there, populated. They just won't play at all. I dont have p6 to test yet but my x5 ss yesterday I had same issue as yours with one of the server but it started to working fine today. 🙂
October 1, 20242 yr 3 hours ago, nbs. said: Have you ruled out your service having issues yet? I think its server side for op as well since I had similar experience with one of the server yesterday beside they tested on p6 and I tested on x5 ss. 🙂
October 3, 20242 yr Author I put my servers on the buzz 5 and vod and series worked fine. So probably not my servers.
October 3, 20242 yr Author At present i'm okay with everything on buzz5 app. I'll wait till they send an update and fix.
October 3, 20242 yr Just now, TonyC said: At present i'm okay with everything on buzz5 app. I'll wait till they send an update and fix. We can't fix it without reproducing it.
October 3, 20242 yr Author I've taken my servers off of buzz6 app and put them on buzz5. What was happening was when pressing ok button on watch on the vod, it would leave the movie homescreen for a second then go back.
October 3, 20242 yr Send a PM to aab with the details on which server you are talking about. As he said. Can't fix what they can't reproduce. Each server is slightly different.
October 3, 20242 yr 2 hours ago, TonyC said: I've taken my servers off of buzz6 app and put them on buzz5. What was happening was when pressing ok button on watch on the vod, it would leave the movie homescreen for a second then go back. I actually only need your MAC sent via PM So we can check the logs as to why this happens. Reproducing it does help more, but we have a built in logger for issues like this as well.
