Recording Problem
I just bought a BuzzTV Classic. Downloaded a few Apps (Global TV, TSN, Sportsnet, CBC Gem). I'd like to be able to record something, but when I press the record button, nothing happens. I'm likely overlooking something simple and hoping someone can point me in the right direction. I've downloaded the manual, but it's really more of a quickstart guide than a manual. Not sure if a more detailed manual exists.
Go to home page ,settings check updates and post what firmware and software are listed
Which remote do you have?
FYI:  Recording only work within the BuzzTV app with your IPTV subscription.  Not with 3rd party apps (like you mentioned: Global TV, TSN, Sportsnet, CBC Gem).
Thanks for the feedback. I guess that's the problem. So I need to subscribe to some sort of IPTV package subscription? I already pay for TSN and Sportsnet subscriptions.
Yes, that is where a buzz box shines.  Unfortunately, IPTV services are not allowed to be discussed on this Forum.  However there are many other forums for that.
