July 11, 20242 yr BuzzTV x5 128ai on projector with using hotspot with my Samsung A53 cellphone and have no sound on application Amazon Prime video also on my local Bellaliant fiber tv. Can't control sound with my BuzzTV remote. It all ask pleased use tv remote control
July 11, 20242 yr Author Sorry but I have BuzzTV XR4000 / XRS4000 OEM Universal IR Remote Control and I can't find the location to change this settings please help
July 11, 20242 yr maybe cause I'm using my ss and not ai right now...lol Edited July 11, 20242 yr by dishuser
July 12, 20242 yr I can't check my ai until tomorrow I lent it my neighbour while he waits for his new box and he worx until 3am
July 12, 20242 yr Author Ok no problem thanks anyway I'm OK I will wait. It's really appreciated your a great.
July 12, 20242 yr Can you try going to Settings->Device Preferences->Display & Sound->Advanced sound settings->Select Formats, and set it to "None: Never use surround sound" And then try again.
July 12, 20242 yr my neighbour said when that happens he uses the remote to control volume using a bt 250 remote
July 12, 20242 yr Author Hey thanks that was it my sound is back. Thank you so much very appreciated.
