January 19, 20242 yr Since update. Buzztv x5 will not connect to wifi. Rebooted internet router and box no change works if connected other than wifi anyone having this problem 5 of my friends also same problem
January 19, 20242 yr Have you tried to FORGET the wifi and then manually select it again and re-enter password ? And when you say it does not connect, does it give you a particular error (like it thinks it is a wrong password), or does it just keep connecting/disconnecting ? If your router offers separate 2.4Ghz and 5Ghz bands, can you try connecting to the other one ?
