November 25, 20232 yr Hello Experts, I have a 11 year old and I wanted to find out if there is a way to have a passcode restriction to view Buzz Box? By default, you turn on Buzz TV and it starts in LIVE tv mode. and anyone can access VOD from there on. Is there a way to childproof this? Thanks!
November 25, 20232 yr None of my buzz boxes have ever gone to live tv by default It's usually home page Adult vod are locked What are you trying to restrict?
November 25, 20232 yr Simple way to Childproof it completely. Take away the remote. There is unfortunately no decent "app" remote. They've be able to unplug and plug it back to get power to the box, but they will just stare at the home screen 🙂
November 25, 20232 yr 3 hours ago, Hhh said: Hello Experts, I have a 11 year old and I wanted to find out if there is a way to have a passcode restriction to view Buzz Box? By default, you turn on Buzz TV and it starts in LIVE tv mode. and anyone can access VOD from there on. Is there a way to childproof this? Thanks! that's not default you set it that way you need to be child proofed from the remote
November 27, 20232 yr Author Thanks for the responses. Taking away the remote is one option, I was hoping not to remember and do that every time parents leave the house. Adult VOD is locked, I am restricting any VOD or any LIVE tv. Trying to find a way for that?
November 27, 20232 yr Depending on the age of the "children" and how clever they are, you could put a remote power plug (like the TP-Link kasa plugs), and you can turn it off when you leave the house. I use a bunch of TP-Link HS-103 to turn off a small space heater in my daughter's room and other devices (like xmas lights) when we are not home and we forget to turn it off. I know older children may catch on and bypass the remote plug adapter, but it is something, better thank nothing 🙂 Guess for you, it would ideal to have an "application" password, which would prevent any launching the BuzzTV 5 LiveTV or VOD app. Unfortunately it is not an option at the moment.
