Slow channel changing
With the new update have had slow channel changing, I've done all the normal things cache, background apps, reboot, unplug internet, nothing has changed.
I did find in live tv menu/settings/configuration go all the way to the bottom to stream format, it was on automatic after the update so i put it back to TS where it was before no difference update made no difference, I put it back to auto now
Everything is set to the way it was before update
Thank you for your time everyone
There is an update going out on Monday (pretty sure) that fixed an issue with one server
Not sure it's the one you're using
It is grabbing epg from xml
would that make difference in channel change speed
I made those changes and put it back to TS seams faster see what happens
Thank you so much for your time
I use auto and it selects hls which is better for catchup channels
my neighbour picks ts like you but doesn't use catchup
Okay maybe I'll put it back to auto see what happens
Okay so with the changes that you suggested dishuser I took and reset my internet and cleared cashe, closed background apps and restarted, everything back to normal
Time to update first a little info:
I have a X5 running provider on xc api, the box plugged into my Marantz SR5003 witch is plugged into my Samsung old plasma tv no cec turned on.
I still have all the changes the same as when i posted last but one.
I had to switch from Primary player to backup because my sound was out of wack with the video witch i have always had to use with any of the buzz box's, and now that i am on backup I have slow channel changes again.
Just a heads up
Thank you everyone for your time
backup player has always been slower than Primary player for channel changes.
BTW: Since you are using XC API, with Primary player, had you tried switching stream type from TS or Automatic to manually selecting M3U8/HLS  ?
The fastest changes i get is using TS, which is close
will leave for now may want to try real time streaming come football time
I use auto and channel changes are instant on same service
by the way auto selects hls
Just a heads up
Backup Player is VLC. Its libvlc as this version doesn't require the GUI and is open source, its main use is for Movies and TV shows. Not Live TV
That's why channel changing is slower.
I don't think this is the spot, but cound not find what i am looking for, trying to find if there is a setting for recently viewed channels for more than just hitting the back button on remote, is there a setting for maybe to view like the last 5 channels you viewed. TY in advance
on bt400 hold down last button (button underneath home button) or if different remote then hold down back/last button for few second.
47 minutes ago, MY2SONS said:
I'll try that when i get back hme tonight
it's the same for every remote
long press brings up last channel history
