Logitech Harmony and Classic?
Does the Logitech Harmony (hub based remote) support the buzztv classic? i cant seem to find it in the harmony database. I read in another sub forum  (XR4500) that buzztv is listed in the harmony database. What is it listed under?
https://support.myharmony.com/en-us/compatibility
in search bar manufacture type buzztv and model type xrs4500
I use a Logitech Harmony Companion (hub) with my BuzzTV XR4500 it works well.
I only use the original remote for the home button.
Classic remote is from a different company,allaboutbuzz should advise
True, but the basic IR codes are the same, no ?  My IR200 still works fine on an X5 and the Classic and vice versa, in IR mode.   OK, it it is BT paired mode, that is a different story.
