May 25, 20233 yr my 4900 keeps rebooting and often gives an error message that buzztv has stopped responding. i have factory reset the box twice. any help would be appreciated.
May 25, 20233 yr Could be power supply, bad hdmi. Try clearing cache too Have you done a hard reset or soft? Edited May 25, 20233 yr by nbs.
May 25, 20233 yr Author i changed hdmi ports and cables. check, did not help. i clean the cache and memory often. check, did not help power supply. ill give it a go, thanks.
May 25, 20233 yr 1 hour ago, roadrunnericu said: i changed hdmi ports and cables. check, did not help. i clean the cache and memory often. check, did not help power supply. ill give it a go, thanks. if not using the original it needs to be 12 volts
May 26, 20233 yr If you try all that and you still have issues, as a "test", remove any media you may have installed in the unit (SD card, Hard drive, USB stick). If there is corruption on the media, it may cause strange behaviours.
