November 18, 20214 yr 5 minutes ago, piskapo said: I had my provider switch me over to Xcode login and everything works cool beans 🙂
November 18, 20214 yr 8 hours ago, piskapo said: I just picked up this box and changed my iptv services to this new box MACID and EPG doesn't show any info. My previous box worked no problems. Anyone have any solutions to this? Macid is shown in the top right hand corner of server settings. The only way to get to the epg is by loading iptv info in server settings, where you will need the Macid to give to your iptv provider to get service. So something isn't here. You don't see the Mac ID but you see epg page.
November 18, 20214 yr 7 minutes ago, Maestro701 said: Macid is shown in the top right hand corner of server settings. The only way to get to the epg is by loading iptv info in server settings, where you will need the Macid to give to your iptv provider to get service. So something isn't here. You don't see the Mac ID but you see epg page. they said they got no epg using mac
November 19, 20214 yr 3 hours ago, dishuser said: they said they got no epg using mac No DU, I was responding to the hijacker. Look again 😂
November 19, 20214 yr 33 minutes ago, Maestro701 said: No DU, I was responding to the hijacker. Look again 😂 and they said they had no epg
November 19, 20214 yr 9 hours ago, dishuser said: and they said they had no epg But also said they can't see MACID. Macid is in server settings and you need that to sub to iptv, which allows you to see channels and epg. So if you can't see Macid how can get to the epg stage?
November 19, 20214 yr 4 hours ago, Maestro701 said: But also said they can't see MACID. Macid is in server settings and you need that to sub to iptv, which allows you to see channels and epg. So if you can't see Macid how can get to the epg stage? no they didn't they said they gave server new mac id and they had no epg not sure what you're reading
November 19, 20214 yr 42 minutes ago, dishuser said: no they didn't they said they gave server new mac id and they had no epg not sure what you're reading I have no idea either 😂
November 19, 20214 yr 19 minutes ago, Maestro701 said: I have no idea either 😂 try reading this then I just picked up this box and changed my iptv services to this new box MACID and EPG doesn't show any info
November 19, 20214 yr 11 minutes ago, Maestro701 said: Yeah I saw it, that's what I said I have no idea what I was reading then you should get hookid on foniks it werkid fer me 🤣
November 20, 20214 yr It's a buzztv big problem and they never resolved it..hope they fix it soon....
November 20, 20214 yr 5 hours ago, Biggy said: It's a buzztv big problem and they never resolved it..hope they fix it soon.... So let me ask...... Suppose your service provide does not have good EPG sources but you DO NOT know about it, but your buzz epg is haywire....... Who do you blame? Does Buzz provide epg sources? No. Does the buzz box grab whatever epg is available? Yes. Does a reseller know everything going on with a service provider? No. Maybe the reseller is just shrugging the user off? Maybe.
November 20, 20214 yr 9 hours ago, Biggy said: It's a buzztv big problem and they never resolved it..hope they fix it soon.... You should start a thread since no one know what you are referring to
