October 18, 20214 yr Trying to record the same show I'm watching. After a few min when I check, the listing is in the PVR but it says fail on the line listing and nothing is there
October 19, 20214 yr Hit the menu button and change setting to one button pvr Now you just have to hit red button and recording should start Also go to settings storage and post what's there Also post what version you have Bottom of screen when you hit menu button
October 21, 20214 yr Insert a USB stick Format stick with buzz then go to pvr settings and change storage location to your USB See if it will record. Would you also post what version of buzz 5 located at bottom of screen when you press menu
