XRS4500 Max and XRS4500 Ultra
Quick question.
I have a XRS4500 MAX box all setup just how I like everything to be, I made a USB flash drive backup of it.
My question is:
Today I am getting a new XRS4500 Ultra for a second box.
Can I use the backup I made for the XRS4500 Max and just load that onto my new XRS4500 Ultra in the restore function?
If I can my new XRS4500 Ultra would be all setup just the way I like everything without me having to go into all the settings and set everything up again.XRS
59 minutes ago, nbs. said:
Should work
I will let you know, I am going to give it a try.
Worst case I will need to do a factory reset on the box if it doesn't work. lol
Just an update, you CAN NOT use the backup file from a XRS4500 MAX box to do a restore on a XRS4500.
I think the problem is the restore backup file is listed as xrs4500max_backup, and it never shown in the restore menu on a XRS4500 .
I think you could only use this as a restore backup to another XRS4500 Max box.
