TS and PVR issues
I’m having issues with TS and the pvr function. TS sometimes appears, and other times it’s there but I can’t go back at all.
the other issue is the PVR will only record a show for 30 min, no matter how long the program is. I have multiple shows recorded, so I know it’s not an actually storage issue, but was wondering if it has to do with how I allowed the memory for TS and PVR
Sorry, got called out to work. I understand that the TS will only work starting when I tune into the channel, but sometime it will happen if I have been on the channel for 20min and still have no TS, other times the “progress” bar on the bottom won’t even show up when I press backwards arrow.
TS is set up for a 9GB cache size, internal storage. I have 51GB of internal storage, and my PVR is also set up for internal storage.
Do the channels you are referring to have Catch-up ?  If so, then you may need to ensure you enable the "Force TS on USB" option, to ensure it doesn't try to use the "server" catchup feature for that.
Doesn't hurt to try it 🙂  I'm at the office, so don't have a box near me.
I typically have an small 32GB stick installed in all my boxes, since I don't like the wear and tear on the internal memory for stuff like this.  If the USB storage wears out from too many read/write cycles, I can easily replace it.  If the onboard memory wears out, then the box is dead.
Thanks, I will try that and I will grab a small external disk as well. Any thoughts about the pvr always stopping after 30min?
I don't have that issue with the PVR, so can't really say. I had set up a recurring daily recording for 45 minutes over a period of 2 weeks, and other than once (when I accidently unplugged the unit), it has always worked.
Maybe try switching the stream type and see if it is any better (in Settings/Configuration, and typically last option).
