April 4, 20233 yr Can't rewind and fast-forward BuzzTV Essentials E2 Max Firmware version V20220916 Last update April 04 2023 Would appreciate your help
April 4, 20233 yr TimeShift setup on BuzzTv 5 1. Connect your usb stick to any of USB port. (USB 3.0 works better if you have available) 2. Go to settings 3. Click storage 4. Click on your usb stick 5. You should see option erase and format as removable storage. So click on it. (If you dont see this option then format your usb first and once done dont use usb as a internal storage. Just click on move later and start from step 3 again. Now you should see erase and format as removable storage option. 6. Click format 7. Once done, now you should see usb as removable storage. 8. keep pressing back until you get to home screen 9. Now click live tv 10. While watching live TV press menu 11. Go to PVR 12. Go to PVR Options 13. Turn on Timeshift 14. Click Timeshift Cache Storage and select your USB and go back 15. Timeshift Cache Size (up to as much you want, 2 GB is good enough) 16 Now when you go to live TV and you should see TS option lid up on bottom right next to CC REC and HD info. If not press info button to see it in bottom right corner. 17. Now you should see white solid line on top of blue line indicating you can go back up to that time. You should be able to use pause and rewind function now. 18. If you dont see TS option in info bar that mean you won’t be able to rewind/pause this channel or stream Edited April 4, 20233 yr by Ryu
April 4, 20233 yr 59 minutes ago, Gilles1945 said: Can't rewind and fast-forward BuzzTV Essentials E2 Max Firmware version V20220916 Last update April 04 2023 Would appreciate your help are we supposed to guess what you're using? kive tv? vod? tv series? youtube?
April 5, 20233 yr Author Thanks Ryu for helping it's very appreciated. Now I did it but it's not working and it could be my fault. I used the SD card instead of usb. That could be the reason why it didn't work. I have included a picture of live TV. And what is funny is the channel I used to rewind. There's no sound while there is a picture. And went no picture I have sound. But I see the TS to the left of CC REC HD 20230405_101814.heic
April 5, 20233 yr 7 minutes ago, Gilles1945 said: Hi dishuser, Sorry but I don't understand what channels have catchup mean?? in guide/epg do you see a play button symbol with a ¾ circle around it?
April 5, 20233 yr Author Thanks I see and those who have the play cercle are working but there's not to many channels that as that. Why they don't have this play cercle. Hey thanks for your you are a good coach.
April 5, 20233 yr 51 minutes ago, Gilles1945 said: Thanks I see and those who have the play cercle are working but there's not to many channels that as that. Why they don't have this play cercle. Hey thanks for your you are a good coach. for those that don't have catchup use timeshift
April 6, 20233 yr Author Thanks again dishuser, What is catchup?? Do we have to pay or have a subscription for catchup?
April 6, 20233 yr 34 minutes ago, Gilles1945 said: Thanks again dishuser, What is catchup?? Do we have to pay or have a subscription for catchup? catchup is stored by the service some store up to 7 days worth not every service has catchup
April 7, 20233 yr Author Thank you very much dishuser hope this is last request. I see that there is a new update apparently of March 3 2023 but I check for update and it say I'm up to date. Current firmware version is V20220916 Current IPTV Version: 5.0.799 Last time checked for update: April 07,09:11AM. So do I have to look for updating in some other way to do the update ?? Edited April 7, 20233 yr by Gilles1945
April 7, 20233 yr that update was not or E2 or android 9. it was andoird 11 devices. 🙂 you are good to go and all set.
April 7, 20233 yr Author So sorry that I have to bug you again. I'm able to pre-register tv channels. But I can't download VOD movie. I get message download fail. In section download VOD all the movies I have chosen are (download failed )
April 7, 20233 yr 2 minutes ago, Gilles1945 said: So sorry that I have to bug you again. I'm able to pre-register tv channels. But I can't download VOD movie. I get message download fail. In section download VOD all the movies I have chosen are (download failed ) are you using xc api?
April 7, 20233 yr also, while downloading are you staying there until it finish downloading or you just exit out screen while it downloading? you have to wait for it to finish download if you are not waiting.
April 7, 20233 yr 45 minutes ago, Ryu said: also, while downloading are you staying there until it finish downloading or you just exit out screen while it downloading? you have to wait for it to finish download if you are not waiting. not if they're using xc api
April 8, 20233 yr Author Thanks again, No I leave to look at something else. I see that we are supposed to wait. Ok So I have to ask what is xc api??
April 8, 20233 yr 25 minutes ago, Gilles1945 said: Thanks again, No I leave to look at something else. I see that we are supposed to wait. Ok So I have to ask what is xc api?? with mac you can't go watch another channel while downloading but you can use an app while downloading or recording for example:youtube
April 22, 20233 yr Author Hi dishuser, What Mac are you talking about. Mac address or MacBook? Also I'm trying to do a backup and after 1 hours it's not done?? Does it take that long?? Thanks
