Catch up not working
I just got a new Classic box but for some reasons the catch up do not work. I get "Media format is not supported" message at the bottom of the TV screen. What settings do I need to change please?
Yes! I have tried with "Backup" player in Live TV video player settings and it doesn't work.
Edited by Polaybuzz
Buzz fixed the issue on your server with the android 9 units
Should be fixed soon with the android 11 units
Thanks, great update, the catch up are working!
However I am forced to use HLS protocol to be able to view catch up with my provider. Is it normal?
Good to hear.
There are 2 stream types usually
TS and HLS
Some work better than others, it varies
So as long as it works, that's all that matters.
