February 21, 20233 yr I have to manually turn it up. Sometimes I have be in the 60 range for volume to be able to hear. Is there something I am doing wrong.
February 21, 20233 yr 25 minutes ago, Dynas said: The box volume has not worked since the last update is your bt-400 set to control tv?
February 21, 20233 yr 25 minutes ago, Dynas said: The box volume has not worked since the last update Have you checked in the settings if the "Max volume" option is enabled ? If MAX Volume is enabled, then you only control volume from your TV (so volume on box does nothing). If Max volume is turned off, then the box has variable volume controlled by the volume buttons.
February 21, 20233 yr 1 hour ago, Dynas said: I do not see the option for Max Volume in settings. go to buzztv utilities
February 21, 20233 yr 1 minute ago, Dynas said: Force Volume ? I have tried that but to no avail. you never answered my question
February 22, 20233 yr Author I have tried the Force volume in Buzz utilities but didn`t make any difference.
February 22, 20233 yr 11 minutes ago, Dynas said: I have tried the Force volume in Buzz utilities but didn`t make any difference. I never asked you about that
