Buzztv X5 no surround sound
Hi,
I just this X5 ai64 this week. Trying to get my surround sound system connected, only thing I can get connected is the TV sound. Any help would be appreciated.
Plus it is still doing some buffering just like my other Android box did, but, not as bad. Any suggestions for this.
For the buffering, If you are on WiFi, it could be a bunch of things.  It could be your service (as nbs pointed out), it could be your ISP throttling (try with a VPN), or it could just be a crappy WiFi signal (your router, placement, etc..).   If you can try with a cable plugged in instead, that would eliminate the WiFi issue at least.
For the surround sound, you don't give enough info.  How you trying to connect it ?  HDMI, optical ?  to a sound bar, receiver, etc.. ?
