HBO max
Hey all,
Has anyone been able to find a working version of HBO max for the buzz?  I've tried on both the xrs4500 and Essentials boxes with no luck.  The Android TV versions of the app don't display properly.  The mobile version of the apk doesn't load files.  Wasn't sure if anyone found a good version of the apk that works on the buzz boxes.  Thanks!
from what i have been reading on a hbo forum they are having quite a few issues
thanks...so issues with the xrs4500 specifically?  It's working on every device I've installed hbo on...it's just the buzz's I can't get going.  Will keep trying.
Where did you download the app from?
So we can try it here and see if we can reproduce + fix the issue
  • 3 years later...
@416guy I need a subscription to the IPTV service. If you can please let me know how to get it.
they haven't been here in almost 4 years
