Ethernet
I cannot get my Buzz Tv switch over to Ethernet . I’ve tried cutting off the WiFi , nothing seems to affect it, I check Ethernet connection also. Any help will be appreciated. Thanks
cutting off? did you turn off wifi in settings?
maybe reboot
try another ethernet cable
you said "I tried cutting off the wifi:  Does that mean you shut it off in settings?
I went to settings and cut off the wifi thinking that may help.  But still when I go down to ETH it still does not connect
With me worked right away when I power of/on the box with the ethernet cable in ofcorse 🙂
