Channels UHF with X5
too often freezes with UHF channels.
But the same channels and the same server do not freeze XRS 4900
UHF channels ?   Are you using the BuzzTV app with some IPTV server provider, or are you using some 3rd party app with some OTA tuner like an HD Homerunner ?  Just curious on why the mention of UHF channels specifically.
If you are using the BuzzTV App through IPTV server, have you tried changing Media player ?
What version of BuzzTV are you running on both devices ?  Check the Updates screen and let us know what version you are running on both devices.
for X5
version     Current.Firmware Version  V20221011
               Current IPTV Version 5.0.775
          Last Time Checked For . Updates : mer 14 dec 2022 19:40
