Vod does not play properly
Hi i tried different servers and same problem where my vod does not play properly. Either it won't play or it starts and than freezes. I tried secondary primary and external players and it does the same thing. It's a buzztv x5 box. Live TV works perfectly
What firmware is on it? And what buzz version
If you check updates it will tell you
I have no issues playing vod on 4 services
51 minutes ago, Rob Brz said:
What about using a specific video player ? Any ideas
I used backup and had no issues on 3 different servers
