power issues
I just purchase a xrs4500 and  when i turn the box off can't turn on again with the remote control need to unplug and plug back on to boot.
I try everything change hdmi wire change power options nothing change
Please help
What firmware are you on ?  If you go to updates, what firmware is listed as being installed ?
Problem with buzz 4000 after turn power off need to unplug and plug power cord to boot box again this started after  I updated box to B5 help
please thank you for any info
1 hour ago, Walter Guzman said:
I have Version V20220919 now also now when I play VOD I get  media player not support thank you very much for any info
how did you update a 4000 to a b5?
did you try a different video player for vod?
I had the same reaction initially 🙂
I think he meant that he updated to BuzzTV 5.  Not to the new BuzzTV B5 box 🙂
Sorry yes my buzz 4000 after I did a reset when
Restart update to new version now everything is working fine thank you
