October 23, 20223 yr Recently upgraded by buzz , not after the update , the remote does not power on the device, everything else works ????
October 24, 20223 yr On 10/23/2022 at 1:42 AM, Scuba1900 said: Recently upgraded by buzz , not after the update , the remote does not power on the device, everything else works ???? Did you Setup the Power button to control your TV by chance?
October 29, 20223 yr I have the same issue with my XRS4900. I’ve paired the remote and it works when the box is on. But if I power off the box (using the remote) I can’t turn it back on. The only way to turn it on is to unplug the box, and plug it back in. Then it boots up and the remote will still work for everything else. But if I turn it off, I have to repeat the same unplugging replugging cycle. I never had this issue before the update.
October 29, 20223 yr 5 minutes ago, Greg said: I have the same issue with my XRS4900. I’ve paired the remote and it works when the box is on. But if I power off the box (using the remote) I can’t turn it back on. The only way to turn it on is to unplug the box, and plug it back in. Then it boots up and the remote will still work for everything else. But if I turn it off, I have to repeat the same unplugging replugging cycle. I never had this issue before the update. you're in the wrong thread
October 29, 20223 yr 13 minutes ago, Scuba1900 said: Which thread deals with this topic ? this is the u5 section so it's not about 4900 issues
October 29, 20223 yr 4 minutes ago, stani035 said: Das gleiche Problem habe ich auch, bitte um Hilfe. do you have a u5?
October 30, 20223 yr Author I did not pair with the TV. I did upgrade the firmware to the latest available. @allaboutbuzz
October 30, 20223 yr 55 minutes ago, Scuba1900 said: I did not pair with the TV. I did upgrade the firmware to the latest available. @allaboutbuzz and what version do you have?
October 30, 20223 yr 1 hour ago, nbs. said: Hit menu button and post the info at bottom they don't have a U5
November 7, 20223 yr Author Can someone confirm how to disconnect and reconnect the remote and the 4900 ?
November 7, 20223 yr home page/settings/remotes & accessories/click on bt-200 and unpair to pair select add accessory and hold ok and -volume buttons at same time until it finds remote then click on remote name to pair
