October 22, 20223 yr Issue with live tv not starting properly. Am on current update . I press live tv and it goes through the loading and then stalls at user profile intil i hit guide then finishes the loading
October 22, 20223 yr 11 hours ago, Woody said: Issue with live tv not starting properly. Am on current update . I press live tv and it goes through the loading and then stalls at user profile intil i hit guide then finishes the loading That could be a server issue too
October 22, 20223 yr Author Im on 779 i have cleared cache and a reset still have same issue . Am on 779 withb new firmware update started happening after the 779 update
October 22, 20223 yr 54 minutes ago, Woody said: Im on 779 i have cleared cache and a reset still have same issue . Am on 779 withb new firmware update started happening after the 779 update Have you contacted your service and asked them to reset your mac?
October 22, 20223 yr Author Its not my server its the update . It only happens with live tv on boot if i turn it off and start live tv manually it does not happen if it were a server issue it would happen in either mode
October 22, 20223 yr Delete server portal then re-instate server portal. I had some issues and that seemed to help.
October 22, 20223 yr 46 minutes ago, Woody said: Its not my server its the update . It only happens with live tv on boot if i turn it off and start live tv manually it does not happen if it were a server issue it would happen in either mode Then reset your box because the update works fine
October 22, 20223 yr Author Already reset it twice... when i boot box up it has a dialoge box pop up briefly then dissappears. Its as if the update did not install properly i even unisyalled update and let it reinstall same issue happens i am on ethernet.
October 23, 20223 yr 1 hour ago, Woody said: Already reset it twice... when i boot box up it has a dialoge box pop up briefly then dissappears. Its as if the update did not install properly i even unisyalled update and let it reinstall same issue happens i am on ethernet. I get the same dialog box but no issues
