September 17, 20224 yr I bought a BuzzTV XRS4500 box yesterday and set everything up. It was working yesterday night and this morning. When I went to turn it on this afternoon, the box won't turn on and the front indicator light won't turn on also. I'm assuming this is an issue with the box itself but just wondering if anyone else ran into the same issue and was able to figure it out?
September 17, 20224 yr Author I've tried multiple outlets, I believe Dishuser might have nailed it on the head with the power supply problem.
September 17, 20224 yr The XRS4500 uses a basic 5V power supply. So if you have a 5V power supply with at least 2A (and same barrel tip), you can always test.
