April 19, 20206 yr You can sort by name date added or or top rated You can view by category and you can search I dont see how a list helps My main server has close to 10000 movies Edited April 19, 20206 yr by nbs.
April 20, 20206 yr Author Well call me old-fashioned but a grid is a much faster method of scrolling through pages of titles.
April 20, 20206 yr 21 hours ago, Peter said: Really? The icon view is nasty paticularily when you can't skip ES. What do you meant can't skip ES?
April 21, 20206 yr 24 minutes ago, Peter said: ES = Spanish When in VOD Press the Red button to open Categories List Press the Red button again to organize categories On here, you will see a list of all categories with an ON/OFF switch If you turn it Off, then the categories will be hidden. After you're finished Press back You will need to reload the VOD to take full affect So just go back to Live, and then re open VOD The categories will now be hidden.
April 21, 20206 yr Author 9 minutes ago, allaboutbuzz said: When in VOD Press the Red button to open Categories List Press the Red button again to organize categories On here, you will see a list of all categories with an ON/OFF switch If you turn it Off, then the categories will be hidden. After you're finished Press back You will need to reload the VOD to take full affect So just go back to Live, and then re open VOD The categories will now be hidden. I take it all back, awesome thanks!
