April 18, 20206 yr Have the XRS-4500 and of late every movie or show I watch in VOD freezes every few minutes. I’ve cleared cache on the buzztv4 app cache, buzztv media player cache and rebooted. tried both the default and the new/secondary player ... same issues. any suggestions to try? Thanks.
April 18, 20206 yr 2 hours ago, DeJesus said: Have the XRS-4500 and of late every movie or show I watch in VOD freezes every few minutes. I’ve cleared cache on the buzztv4 app cache, buzztv media player cache and rebooted. tried both the default and the new/secondary player ... same issues. any suggestions to try? Thanks. Never have that problem ,try with the secondary player ,if is the same either is ur internet connection or the server.
April 18, 20206 yr Author 7 hours ago, Nelutz said: Never have that problem ,try with the secondary player ,if is the same either is ur internet connection or the server. Tried it already same issue. Have wired Ethernet so that’s not the issue. Same provider on older xpl3000 works fine. Will try today and see. Thx.
April 18, 20206 yr 3 hours ago, DeJesus said: Tried it already same issue. Have wired Ethernet so that’s not the issue. Same provider on older xpl3000 works fine. Will try today and see. Thx. Hmmm, install speedtest either from the Appstore or Aptoide and do a speed test ,see how much speed is the box getting,it might be your internet speed. Edited April 18, 20206 yr by Nelutz
April 19, 20206 yr Author 10 hours ago, Nelutz said: Hmmm, install speedtest either from the Appstore or Aptoide and do a speed test ,see how much speed is the box getting,it might be your internet speed. 219-228Mbps constantly. I have 250 mbps package and it’s hardwired/Ethernet connected.
April 19, 20206 yr Author 13 hours ago, nbs. said: was xpl3000 in same location? No, in a different room. But also Ethernet
April 19, 20206 yr Author 13 hours ago, nbs. said: was xpl3000 in same location? No. Different room but also hardwired/Ethernet connected .
April 19, 20206 yr 10 hours ago, DeJesus said: 219-228Mbps constantly. I have 250 mbps package and it’s hardwired/Ethernet connected. Ok with this speed it not supposed to freeze ,now if the speed is not a issue ,than could be that this server doesn't like the xrs4500(u post it that it works fine with the xpl3000).
April 20, 20206 yr I have noticed this issue too. Its intermittent. Usually, rebooting the app/device has helped.
