Channel quality info and auto start buzz app
As a reseller I've sold only buzz boxes for 3 years and I've owned pretty much all iterations of the buzz ...I'vealways wanted 2 features....
1.  Show channel info - resolution and framerate
2.  Auto startup buzz app from bootup of box
Any chance that may come in a future update?
Thanks!
dont think there has been any talk of resolution and framerate ,auto start up already exists
Ah yes. Forgot about that you're right about Auto startup.  I've been asking for that since the first buzz units came on the scene.
At the release party at buzz a couple months ago the talk was that the 4500 series was for the techy people and i had mentioned  to one of the guys at buzz that  alot of heavy Iptv users use framerate and resolution quite a bit.  As resellers that info is even more important.
Hopefully we will see this in a future update.
the 4000 will have it too if it doesnt already
for those that dont know go to buzz utilities ,power options and chose your option
Thanks!
1. We will try to add in a future update.
2. Already exists under Configuration menu of Buzz
For the 4000s + 4500s
Sweet!
What about adding favorites channels to the home screen like the mate1 boxes have?  I'm not sure if the 4000  series has that feature.
Yes it has this feature
Just open Buzz Utilities
You will see option for Home Screen Rows
We even added rows for TV Series + VOD Favs to 4000s + 4500s
Awesome!
