5.0 Resume/Audio issues
Anyone having issues coming back from Standby? I just get a spinning circle and no channels load. If I reboot the box and reconnect to the portal, all is fine.
Another issue I noticed with 5.0 is the wildly uneven audio levels between channels. I basically have to constantly adjust the audio levels, one channel is a feint  whisper while another is way too loud.
Thanks.
I always shut down so I can't help you with the standby
The volume levels would have to be modified at the server
I don't recall 4.X having the issue at that level. Literally with the same audio interface level, channel 123 is almost a whisper  while channel 124 is very loud. There also seems to be a greater lag between the audio popping up than 4.X did.
22 minutes ago, dishuser said:
have you tried the other player?
The other player being? I noticed VLC was the default, how do I change players?
I leave mine on standby and just hit refresh from menu and works fine. sometimes I had to go channel up or down and that depends on some servers but most work fine with refresh. 🙂
I have the same problem with the video. Turning off "start in live TV" in power options got rid of the freezing wheel, but you need to hit the live TV button after coming out of standby to refresh the picture. That gets you back online right away when using the secondary player, which works better than the default.
I believe this is being looked into.
6 hours ago, dishuser said:
menu/settings/configuration
The default basically goes back to the same 4.x behavior so you lose all the information concerning the feed (i.e. resolution/audio).
but did it fix other issues?
It seemed better, I reverted back to the secondary once I saw the loss of functionality. The default basically has no video feed metadata information whatsoever.
so you watch the data info not the program? 😆
