Firmware update for 4900
4 minutes ago, dishuser said:
our remote is working cause it's a dual
you're in IR mode not BT
Ah, ok. Thanks for the info.
How can I enable or fix the BT mode?
select add accessory
then hold ok and volume down button while it scans
when it finds bt-200 click on it and then pair
Unfortunately, this does not work, because the app keeps reporting the error message "Bluetooth keeps stopping" in between. Pairing does not work. I suspect that the APP on the XRS 4900 does not work correctly or does not really remain active. 😪
I'll try again tomorrow. First of all, thanks for your effort.
7 hours ago, dishuser said:
if wifi is on turn it off or vice versa
then pair bt
The box boots up, and immediately the message "Bluetooth keeps stopping" is displayed with the choice of "App information" or "Close app". With more clicks on "Close App" I close the "window". In the settings, Wifi and BT are grayed out. (I have Wifi set to off by default.
After I enabled WiFi and also enabled BT, all paired devices are displayed under "Remote & Accessories".
(see screenshot)
I am happy. Many, many thanks. And sorry for my bad english.
(see screenshot)
I had this same issue when I updated it a few days ago. You need to go into the apps>system apps> bluetooth, then clear cache and force stop. Restart box, go to WIFI, enable WIFI, go to bluetooth, enable bluetooth, issue will be gone. You can now pair your bluetooth remote and you wont see that error anymore.
Exactly, so in such a way I have it with the active assistance of "dishuser" again. You just have to know how to do it and the search in the forum did not really bring me to the goal. 👍
  • 3 weeks later...
Do they send updates through the stream often, i am missing a few i think, haven't had box on since ver 5.0.653
anyone know where to find the verbage discriptions for latest IPTV version updates, evertime my box updates, '
I dont have the time to read the changes, would like to go back and reread, if possible!
