February 12, 20224 yr Hello when I had Buzz4 on my xrs4500 all streams worked fine...Live, VOD, TV series....I upgraded to Buzz5 and now I can't any USA based streams to work.." Stream not available" strange thing is all others work. Called my provider and he did everything on his side and said must be a Buzz5 problem. Anybody else have this problem or a known fix ? Thanks
February 14, 20224 yr On 2/12/2022 at 3:15 PM, skyeking69 said: Hello when I had Buzz4 on my xrs4500 all streams worked fine...Live, VOD, TV series....I upgraded to Buzz5 and now I can't any USA based streams to work.." Stream not available" strange thing is all others work. Called my provider and he did everything on his side and said must be a Buzz5 problem. Anybody else have this problem or a known fix ? Thanks I had this from the moment they released the beta ,and still have it on some servers,with the primary player and most with secondary player, waiting on a new update.
February 20, 20224 yr Author On 2/14/2022 at 3:20 PM, nbs. said: You should also mention your services worked fine on other 4500s Yes it worked fine on Buzz4.....just when I updated to Buzz5......only USA channels......still the same.......Hello BuzzTV..any updates coming ?
February 20, 20224 yr 5 minutes ago, skyeking69 said: Yes it worked fine on Buzz4.....just when I updated to Buzz5......only USA channels......still the same.......Hello BuzzTV..any updates coming ? you never answered the question nbs. asked
February 21, 20224 yr Author On 2/20/2022 at 1:56 PM, dishuser said: you never answered the question nbs. asked Cause I don't understand it...."other 4500s" ?
February 21, 20224 yr 23 minutes ago, skyeking69 said: Cause I don't understand it...."other 4500s" ? he asked if you tried both players
February 23, 20224 yr Author On 2/21/2022 at 2:30 PM, dishuser said: he asked if you tried both players ahhh Thanks switched to default player....working now.....Thanks!!
March 16, 20224 yr Hi, I also have a similar issue where on some channels there is no audio and you have to switch to default player and it works except with the default player you can’t watch catch up.
March 16, 20224 yr 5 minutes ago, BuzzedOut said: Hi, I also have a similar issue where on some channels there is no audio and you have to switch to default player and it works except with the default player you can’t watch catch up. before switching players have you tried pressing green button?
March 16, 20224 yr 13 minutes ago, dishuser said: before switching players have you tried pressing green button? Thanks. Yes and the audio is set to disabled. If I change it to stereo I get decoder initialization error and then nothing plays. I also have another buzz xrs4500 running buzztv 4 with no issues on that channel with the secondary player set
March 16, 20224 yr I left it on for about 3 mins. If I’m on live tv it will be black screen with a spinning circle and that decoder message and nothing seems to happens changing it back to disabled works playing video but no audio. If I try it on catch up with either epg or single epg it will just display the decoder message and nothing happens with the guide still in place. If i have it by default setting for that ch to disabled the catch up video works but no audio and changing it while on catchup to audio it displays the decoder message and exits to live tv. No issue with using default player except it doesn’t work with catchup
