Yesterday at 09:20 AM1 day My BT-250 remote got dropped and now sometimes doesn't register button pushes. I have a classic box, can I buy any remote or is there a specific one I should buy? I was thinking about buying the GR-303 air mouse.
22 hours ago22 hr Buy from here any original remote control. BuzzTV DirectRemotesBuzzTV Powered by Android™. The Custom BuzzTV 5 App Will Transform The Way You Way You Watch Television. Experience Fast Steaming, Ultra 4K HD Picture Quality & Live Streams All Around The Globe. Get
20 hours ago20 hr Check the remote carefully and make sure it is snapped closed properly. Wife drops my older BT200 often and when it doesn't seem to register, it is always because the case has slightly split open (barely visible). Quick squeeze/snap back together and works fine again.And I would stick with an original remote (like Ryu mentioned above). Otherwise you will have "fun" trying to map the buttons (colored buttons, menu, info, last channel, etc..). Not worth the hassle.
