Catch up problem
Hello i have an new problem after new firmware when in watching something
In catch up i cant pause the program anymore that have been working before
I think
Don't know where you got a pause feature, but I checked on v330 and on v347 and there is no pause functionality.  I don't even see how you would actually pause since there is no obvious play.pause control.   I can go forward and backwards no problem, but there is no pause control as far as I can see.  And just pressing the OK button does NOT play/pause.  Maybe that would be more of a feature to be added, similar to when you are playing VOD and OK button will toggle Play/Pause icon which is on the left.
pause and play can be added very easy by pressing arrow down and have additional buttons like paus and play using ok button. 🙂
I'm sure it was just an oversite and Buzz will add it.   Considering the OK button does nothing when you are playing Catch-up anyhow, figured may as well do it like VOD (no need for arrow down) and have it just toggle play/pause directly on screen which shows the timeline which you can FWD/RWD through the Catch-up anyhow.
Ok i see i maybe thought it was possible but im thought on my formuler maybe
And there is it possible to pause the Catch up so buzz i would like this feature for sure
did you even read the replies?
