u5 pvr issues
I programed pvr for a 1 hour recording for multiple days but only get 15min of recording.
I have factory reset the box several times. using a 500gig solid state hd (samsung) . I've tried removal usb and internal storage.
Any ideas..
You using mac or xc api?
Is your server very stable? If it isn't any interruption will stop the recording.
Can you record what you are watching?
Even if you are using XC, if you start to channel surf, the number of connections can go up and the server does not close other connections fast enough, and therefore you can hit your connection limit and server can cancel the recording stream.
