BT-350 voice remote
Will the BT-350 voice remote work with the U5, I am interesting the voice functions, will they work with the U5?
I take it from no response from anyone the BT-350 voice function will not work on the U5 box, am I correct?
Even it it did work, if I recall correctly with the P6 (BT500) the voice function only works outside of the buzztv app (I did very limited testing on voice functionally).  So mostly commands from home screen.  It's quicker to just use the remote to navigate anywhere I want for the amount time it would take to speak the command 🙂
Not particularly useful in my opinion.  Don't expect Alexa, Google or Siri type of interaction with any of the boxes.
I use voice for google
