June 11, 20251 yr When I turn off my TV using my TV remote, it changes the channel on my STB. Even when I turn off my TV using the button on the TV, it changes the channel on my STB. This being the case, I cant start a recording and go to bed because I know shutting off my TV will stop the recording and change the channel on my STB. The only workaround that I've found, and it's not a good one, is to leave my TV on all night. Does anyone know a better workaround?
June 12, 20251 yr Author I just tried that but to no avail. When I turn off the TV with the Buzz remote, the stb channel still gets changed to channel 8 (BBC 4). I think it may be something Buzz needs to address in a future update. Until then I will have to leave my TV on all night.
June 12, 20251 yr 48 minutes ago, allinghj said: I just tried that but to no avail. When I turn off the TV with the Buzz remote, the stb channel still gets changed to channel 8 (BBC 4). I think it may be something Buzz needs to address in a future update. Until then I will have to leave my TV on all night. unfotunately an update will not change IR functions
June 12, 20251 yr 1 hour ago, allinghj said: I just tried that but to no avail. When I turn off the TV with the Buzz remote, the stb channel still gets changed to channel 8 (BBC 4). I think it may be something Buzz needs to address in a future update. Until then I will have to leave my TV on all night. We use the NEC Protocol for IR Codes, so do many other devices like LG Sometimes they overlap between other devices This isn't something we can fix unfortunately
June 27, 20251 yr Author I found a work around (sort of). If I'm watching something at night and I want to go to bed here's what I do. I set the timer record to start in 2 minutes. Then I shut off my TV before the timer recording starts. That seems to work but I miss a couple of minutes...no big deal. I would encourage the Buzz folks to keep working on this issue. It must be solvable because neither my Formuler nor my Dreamlink have this issue.
