April 14, 20251 yr Which one do you guys have? Which one are you happy with and which one are you not happy with?
April 14, 20251 yr I don't recommended here other than buzztv hardware/software. however, something I like you may not like or something works for you may not work you. most of the vpn nowadays offer up to month with money back guarantee. I would say try and see how that works for you.
April 16, 20251 yr I've been using Windscribe, works very well and has a nice big interface. Make sure to download windscribe-tv.apk it's the Android TV version. If you get the phone version you won't like the interface. They offer free of 10GB per month, but look at the paid version. I am not affiliated with them in anyway.
April 16, 20251 yr 23 minutes ago, dishuser said: 10gb isn't even one 4k vod so forget about the free version...lol But you typically don't need VPN for VOD. At least in my case, VOD and TV Series I have never needed to use VPN (with at least 3 different services - but could be different for others). And 10GB is plenty for a few hours of LiveTV, as a test to confirm if VPN will help your situation (assuming you have blackouts/throttling). The 10GB is NOT for permanent use, since you will run out if used for daily use. I've been using windscribe (amongst others) also and no issues either. I like their AndroidTV client. And you can get pretty good pricing (less than CDN$3/month) if you look through sites like stacksocial, and stacksocial often has additional discounts above the discounted price. Many other services like ipvanish also offer a decent product with reasonable pricing.
April 16, 20251 yr I got three years unlimited for some ridiculousness low price. At your recommendation Emporium, I might add 😄.
April 16, 20251 yr 44 minutes ago, Emporium said: But you typically don't need VPN for VOD. At least in my case, VOD and TV Series I have never needed to use VPN (with at least 3 different services - but could be different for others). And 10GB is plenty for a few hours of LiveTV, as a test to confirm if VPN will help your situation (assuming you have blackouts/throttling). The 10GB is NOT for permanent use, since you will run out if used for daily use. I've been using windscribe (amongst others) also and no issues either. I like their AndroidTV client. And you can get pretty good pricing (less than CDN$3/month) if you look through sites like stacksocial, and stacksocial often has additional discounts above the discounted price. Many other services like ipvanish also offer a decent product with reasonable pricing. most people use a vpn so there's no trace as to what their activity is I know I do
