April 2, 20251 yr When I go to search, and start typing in a channel name, the letters repeat....like aaa. Can I slow down the speed so that doesn't happen?
April 2, 20251 yr I do not have such an issue. What remote are you using ? A little more info would help. If it is the standard BT250 that came with the Classic, then there is obviously something wrong with the remote. If it is paired (Bluetooth) try to unpair/forget it, and re-pair it. When you unpair it (before re-pairing it), can you try with just IR and see if the same persists ?
April 3, 20251 yr Author It's the upgraded remote with the keyboard. Actually I think I may have solved the issue. I used the "pointer speed" setting to slow down the pointer and I think it may have also slowed down the typing...no repeating letters so far.
April 3, 20251 yr 12 minutes ago, allinghj said: It's the upgraded remote with the keyboard. Actually I think I may have solved the issue. I used the "pointer speed" setting to slow down the pointer and I think it may have also slowed down the typing...no repeating letters so far. so it's one of 4 remotes...lol
April 3, 20251 yr Author And here I thought my fancy remote put me in the "elite" club. Is there a model number on it some where?
April 3, 20251 yr 17 minutes ago, allinghj said: And here I thought my fancy remote put me in the "elite" club. Is there a model number on it some where? https://buzztvglobal.com/en-ca/collections/remotes
