Remote unpaired
Hey guys, rolled over on the remote last night and the screen to pair remote came up. Before I knew it it had disappeared and I noticed the remote is not paired.
I tried to pair it but it's not happening. The device sees it and I click to pair but nothing happens.
Assuming you selected Pair new device, and then put the remote into pairing mode (pressing OK and VOL- for 3 seconds till light starts flashing) ?
Manual for BT-250 is here, and pairing is Step 7.
https://buzztv.com/wp-content/uploads/2023/01/Classic_manual-v1_MOBILE.pdf
Try power cycling the machine ?  And/or turning BT off then on again ?
I did all that, yeah I have the manual from before but the remote control screen is not coming up
Interesting to find out what "shortcut" I might have pressed to unpair the remote. Maybe it's the same one that pairs it. Won't be home until a few hours but if one of you guys can try it would be appreciated.
long press info button
OK this may not be even close But what I think happened is when you sat on the remote you hit a bunch of buttons and confused it or the stb and it just took abit for it to recover
Oh wow. All this time I never even realized long press of info button would delete a paired remote 🙂
I just tried it on my X5.. I have by BT400 paired to it, and a BT250.   Long press info once on my bt250, and it deleted the bt400 (probably since it was at the bottom of the list and/or added last).  Long press a second time and it deletes the BT250.  I have probably done that a few times without realizing it, since the info button is just under the "last channel" button which I often long press 🙂
Thnx
You're crazy mann 😂
