Home screen appears remote not working, new batteries
System was working fine for two months now remote has stopped pairing. Buzztv home page appears but unable to navigate. Initially could turn tv on off with remote can no longer do so...
You didn't need to revive and 8 month old post ?  Could have started your own thread.
A little more info would help.  What model box do you have ?   When you press buttons on the remote, is there any LED or sign of life on the remote.  Have you changed the batteries with a fresh set ?
Check the Remote factory reset section and try to reset the remote:
https://buzztv.com/wp-content/uploads/2022/07/BT400-300_manual_MOBILE_v6_Compress.pdf
