December 27, 20214 yr 59 minutes ago, A C said: Have any one ever have sound loss issues? If so how did you solkve it? sound on which app(s)?
December 27, 20214 yr Author 1 hour ago, mr man said: Unplug the power cord and plug it back in Thanks, i will try that...
December 27, 20214 yr 27 minutes ago, A C said: Buzztv5 have you tried other player or pressed green button to check audio?
December 27, 20214 yr 2 hours ago, A C said: Have any one ever have sound loss issues? If so how did you solkve it? No, haven't experienced it on this model. Does the sound just go out randomly or when a channel freezes/buffer?
December 27, 20214 yr Author 2 hours ago, Maestro701 said: No, haven't experienced it on this model. Does the sound just go out randomly or when a channel freezes/buffer? Yes randomly for about 2 hours on a channel and the sound returns. No buffering or freezes
December 28, 20214 yr 41 minutes ago, A C said: Yes randomly for about 2 hours on a channel and the sound returns. No buffering or freezes Are you saying there is no sound for 2 hours on a channel or that it happens randomly about every 2 hours?
December 28, 20214 yr Author 1 hour ago, Maestro701 said: Are you saying there is no sound for 2 hours on a channel or that it happens randomly about every 2 hours? No sound for 2 hours on any channel. It happens once every day. I know thats craazy right. (LOL)
December 28, 20214 yr Author 1 hour ago, nbs. said: have you ruled out your service? Yes because i have four buzztv boxes. And just bought another one.
December 28, 20214 yr 1 minute ago, A C said: Yes because i have four buzztv boxes. And just bought another one. you need to post more info
December 28, 20214 yr 7 minutes ago, A C said: Yes because i have four buzztv boxes. And just bought another one. did you try what I suggested?
December 28, 20214 yr Author 4 minutes ago, nbs. said: you need to post more info I be watching a channel (Starz) my my favorite and the sound go out and let it play and boom the sound returns few hours later.
December 28, 20214 yr Author 3 minutes ago, dishuser said: did you try what I suggested? No not yet, going to do that.
December 28, 20214 yr Author 6 minutes ago, A C said: No not yet, going to do that. It only happen on the xrs4900 not the xrs4500
December 28, 20214 yr Author 5 minutes ago, nbs. said: which video player are you using? I tried them both, The Default & Secondary.
December 28, 20214 yr Yes The new Buzz5 update will fix this told the secondary player will the primary choice testing on the 4500 box it’s smooth !!!
December 28, 20214 yr 9 hours ago, A C said: No sound for 2 hours on any channel. It happens once every day. I know thats craazy right. (LOL) This has got to be your iptv service no doubt.
December 28, 20214 yr Switch out the hdmi cable with one of the others and see what happens. If you get the same issue then bro it has to your service.
