4500xrs problem with Nord VPN
I have loaded Nord onto my 4500xrs. It works however I cannot control it. The connection page does not respond to disconnect commands.
Anyone have any ideas whether there is an issue with the 4500xrs and Nord?
I have an X5 also and there are no problems between it and Nord.
do you use mouse cursor? also, try a pc mouse and see if that helps.
I know windscribe has 2 versions for Android.  One for generic Android boxes, and one for AndroidTV (tagged as for the Nvidia Shield).  I always use the AndroidTV version since it is the one that the remote works as expected with it, without needing mouse cursor.  I know the Android 9 boxes were not AndroidTV, but either way, it works beter even on those.
Try downloading the AndroidTV version and manually install that and see if it is any better.
https://downloads.nordcdn.com/apps/android/generic/nordvpn-sideload/latest/v2/NordVPN_TV.apk
