P6 Buzz6 not loading XC Servers
Yes, I will be at Buzz HQ next week. Love the P6, but understand programming issues.
Thanks everyone for you help.
Still have 2 Killer XRS4900 MAX as back up. And a U5
https://www.youtube.com/@BuzzTVGlobal
you can also check their channel. they have lots of great videos and info about their products. 🙂
Ok seems to be working, will try others that would not load, why is plug-in on new server blue not white?
Ok seems to be working, why is plug-in top right corner of new server window blue not white?
good to hear that. 🙂
I dont know as I dont have this unit hopefully someone with this until will be able to answer you. 🙂
Hi razor07 can you show us a picture or a screen shot?
Well if I think I know what you mean The blue means the one you are connected to
I have 2 servers on XC and the one connected is blue and the other is white
thank you sir. 🙂
I just loaded another xc server, which will make 3, when there were 2, 1 white, 1 blue, so I switched to white 1 blue turned red. Now 2 white, 1 blue which I was one, switched server, the 1 I was turned red, I am starting to understand, the main thing is the problem was solved thanks to all.
thats how we learn. good stuff 🙂
you can also see which server portal is connected while viewing LiveTV.
While on a channel, press the Down key pad on the RCU and the server name will appear there in that bottom info bar.
in the past, naming a server was not so much  important, but now naming the server portal with a descriptive name comes into play 🙂
thank you 🙂
thats actually pretty cool. 🙂
This is what I am getting on 1 server that was good before?
Edited by allaboutbuzz
Shouldn't post photos of servers
All was good yesterday, even did a recording, which was fine. Now I am back to square 1 with channel stream errors on 2 servers and 1 has no guide. Cleaned cache, unplugged same?
Did you message allaboutbuzz with your info the other day when I suggested it?
Sorry about that did not even think that would be a problem, will not happen again.
Sorry, I did not think that would be a problem.
Yes, there is a fix in the works.
Thank you for your help.
Mark7
