Probleme avec telecommande
J ai un probleme avec mes telecommandes buzztv. j ai le buzztv xrs 4900, et je voudrais une telecommande air mouse. j en ai essayer 2-3 dont ARQ-200. ARQ-250 . ARQ-100 et mon probleme c est que les batteries sont morte apres 3-4 semaines . j ai beau changer les batteries de bonne qualite et rien ne fait. Toujours la meme chose,les batteries tombe toujour mortes. Je ne sait plus quoi faire.
I tried ages ago to use rechargeable, but the 1.2V vs 1.5V makes them not last as long either.  Sure you can just swap them in/out with another set of rechargeables and costs close to nothing, but it can be annoying.
Backlight can be a killer.  With rechargeable, they fade super fast.
I really like the BT200 for the super easy shortcut to turn backlight on/off without even needing to see the remote.  Long press bottom rightmost bottom button and it toggles.. It was genius 🙂
Kill the backlight and batteries last for ages, especially if you use quality batteries (Duracell or Energizer - like buzz includes 😋).
OK je vais essayer des pile rechargable et je vais voir
