August 24, 20242 yr 3 hours ago, dishuser said: january 1st the year one trillion 🤣 can I borrow couple of years from one trillion please 🤭
August 24, 20242 yr 1 minute ago, Ryu said: can I borrow couple of years from one trillion please 🤭 then I would have to rewrite my will 🙃
September 7, 20242 yr Author With an XC api, do you have to tell your provider when swapping boxes? Only in a thread I read, said you can use XC multiple times, but on different boxes?
September 7, 20242 yr 1 minute ago, TonyC said: With an XC api, do you have to tell your provider when swapping boxes? Only in a thread I read, said you can use XC multiple times, but on different boxes? No. In most cases you do not need to. There are options available to resellers on the panel to lock XC subs to various stuff like ISP, IP, Country, user agents reported by box, etc... They are rarely used unless some account is being hacked. I have my same XC account installed on at least 10 different boxes, and no issues. That is very convenient. As long as i don't go over my number of simultaneous active streams, it does not matter how many boxes it is installed on.
