May 4, 20242 yr Hello, Using BUZZ box XRS4500 since few years. I notice that SUBTITLES option always has the RADIO BUTTON on DISABLED. I checked with supplier and he can see it on other players he uses. What can I do to get subtitles to work? Thanks for the help Edited May 4, 20242 yr by Hhh
May 4, 20242 yr LiveTV, VOD, TV Series ? Have you tried changing Players in the config menu ? BuzzTV version ? (and please don't say "lastest one".
May 7, 20242 yr Author This is for VOD. Subtitles do not show up. The option default lists them as DISABLED. I use XRS4500 Version 9. Build V20220106.20220106 Kernel:4.9.113 Regarding Changing Players:-For Home Screen I see a Media player2 as selected (other options are classic, media player and mordern). I have never touched this setting. I assume this was ok. I just noticed that even for LIVE tv, I see an option to make SUBTITLES as CLOSED CAPTION 1, but I dont see any subtitles.
May 7, 20242 yr classic, media player and mordern are themes.. Nothing to do with the players.. In LiveTV, press Menu->Settings->Configuration and the top 2 entries are to select player for LiveTV and VOD/TVSeries.
May 7, 20242 yr Author In Menu - Settings - Configuration I see LIVE TV set to Primary and VOD set to secondary. If I select them, the only change I can make is change primary to backup and vice versa. I will take your advice and make change VOD to External - so that it can prompt me - and then I can try VLC, etc. (I didn't realize using an outside app is better than using Buzz defaults)
May 7, 20242 yr 7 minutes ago, Hhh said: In Menu - Settings - Configuration I see LIVE TV set to Primary and VOD set to secondary. If I select them, the only change I can make is change primary to backup and vice versa. I will take your advice and make change VOD to External - so that it can prompt me - and then I can try VLC, etc. (I didn't realize using an outside app is better than using Buzz defaults) you need to update
May 7, 20242 yr Author FYI:- In VOD, When I select VLC to play the subtitles: I click the Down Arrow for Subtitles where it shows me download subtitles, load subtitles: when I select download Subtitles - it doesn't have anything to download. so Subtitles don't appear with VLC. For Update: I go to Buzz TV System Update:- It tells me LATEST UPDATE INSTALLED. It shows me the same number I provided here earlier:20220106. >>"you need to update" - to which version and how?
May 7, 20242 yr Author Here is what I have:- Buzz TV 5.0.919 Updated on 02/09/2024. As mentioned, it does not show me any updates to install.
May 7, 20242 yr 10 minutes ago, Hhh said: Here is what I have:- Buzz TV 5.0.919 Updated on 02/09/2024. As mentioned, it does not show me any updates to install. as I said that's current if it shows subtitles disabled then there isn't subtitles for live tv I only get subtitles using backup player and the odd channel using primary Edited May 7, 20242 yr by dishuser
May 7, 20242 yr Author I am not seeing subtitles for any player. Primary or Backup. LIVE or VOD. I even tried with VLC. ( details mentioned above)
May 7, 20242 yr Just now, Hhh said: I am not seeing subtitles for any player. Primary or Backup. LIVE or VOD. I even tried with VLC. ( details mentioned above) maybe the service you use doesn't carry subtitles
